Introdução
This guide shows how to replace the USB 3.0 port on the Lenovo Yoga 920-13IKB.
O que você precisa
Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
3 outras pessoas executaram este guia.
Um comentário
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
