Ir para o conteúdo principal
Lenovo Yoga 920-13IKB USB 3.0 Port Replacement
O que você precisa
  1. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 2, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 2, imagem 2 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 2, imagem 3 %32
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: passo 3, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement, USB 3.0 Port: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the red and black wire connected to the speaker using the iFixit Tweezers.
  4. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 4, imagem 1 %32
    • Lift up the black tab on the flat cable connector with the iFixit Opening Tool.
  5. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 5, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 5, imagem 2 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 5, imagem 3 %32
    • Flip up the tab using the iFixit Tweezers to release the flat cable.
  6. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 6, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 6, imagem 2 %32
    • Undo the two 3mm Phillips #00 screws to loosen the USB 3.0 board.
  7. Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 7, imagem 1 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 7, imagem 2 %32 Lenovo Yoga 920-13IKB USB 3.0 Port Replacement: passo 7, imagem 3 %32
    • Remove the USB 3.0 Board from the device using the iFixit Opening Tool.
Conclusão
3 outras pessoas executaram este guia.
Alyssa McCulloch
Membro desde: 01/24/19
1.921 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S2-G3, White Winter 2019 Membro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
Membros da 4
Autoria de 29 guias
Um comentário
Just wanted to say thank you to Alyssa and the others who contributed to this.
I just used your guide to fix a problem with my Yoga constantly entering and waking (repeatedly, seconds apart) from connected sleep mode. Infuriating. It was accompanied by the USB connect/disconnect sound as well.
Using the Event Viewer I managed to find out it was entering sleep mode in response to the power button (which I wasn’t pressing). So, I used your guide to disconnect and reconnect the USB board and it has resolved my issue.
iFixIt gained some tools income, you gained some more reputation points, and I gained a laptop that’s behaving itself now!
Now, what else can I break? ;o)
Sean Puffett - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Duração total: 2,094
