Ir para o conteúdo principal
Lenovo Yoga 920-13IKB USB - C Port Replacement
O que você precisa
  1. Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 2, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 2, imagem 2 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 2, imagem 3 %32
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: passo 3, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the twelve 5mm Phillips #00 screws to loosen the motherboard.
  4. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 4, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 4, imagem 2 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 4, imagem 3 %32
    • Flip up the ten flat connectors holding the motherboard using the iFixit Opening Tool to free the motherboard.
  5. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 5, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull out the ribbon cables from the opened connectors using the iFixit Tweezers to free up the motherboard.
  6. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 6, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 6, imagem 2 %32
    • Disconnect the battery by pulling the ribbon wire grouping out of the top of the motherboard.
  7. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 7, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 7, imagem 2 %32
    • Disconnect the red and black wire from the motherboard using the iFixit Tweezers.
  8. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 8, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 8, imagem 2 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 8, imagem 3 %32
    • Lift the motherboard up parallel to the hinge of the device.
    • Gently pull away from the port cutouts of the USB-C and audio jack to remove the motherboard from the device casing.
    • Avoid pulling the motherboard all the way out until the green AC card is disconnected.
  9. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 9, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 9, imagem 2 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 9, imagem 3 %32
    • Disconnect the green AC card plugged into the motherboard by pulling it out with your hands.
  10. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 10, imagem 1 %32
    • Flip the motherboard over to access the back side.
  11. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 11, imagem 1 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 11, imagem 2 %32 Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 11, imagem 3 %32
    • Remove four 3mm JIS #00 screws with the screwdriver.
    • Remove one 3mm Phillips #00 screw with the screwdriver.
    • The screws stay attached to the speaker when removed from the motherboard.
  12. Lenovo Yoga 920-13IKB USB - C Port Replacement: passo 12, imagem 1 %32
    • Separate the fans from the motherboard to isolate it for replacement.
  13. Lenovo Yoga 920-13IKB USB - C Port Replacement, USB - C Port: passo 13, imagem 1 %32
    • Replace the motherboard to replace the USB-C ports.
Conclusão
3 outras pessoas executaram este guia.
Alyssa McCulloch
Membro desde: 01/24/19
1.921 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S2-G3, White Winter 2019 Membro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
Membros da 4
Autoria de 29 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 54
Duração total: 6,224
