Ir para o conteúdo principal
Lenovo Yoga 920-13IKB Battery Replacement
O que você precisa
  1. Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 920-13IKB Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the device over to access the screws on the back cover.
    • Remove the ten 5mm Torx T5 screws on the back cover to loosen the back cover.
  2. Lenovo Yoga 920-13IKB Battery Replacement: passo 2, imagem 1 %32 Lenovo Yoga 920-13IKB Battery Replacement: passo 2, imagem 2 %32 Lenovo Yoga 920-13IKB Battery Replacement: passo 2, imagem 3 %32
    • Slide the iFixit Opening Tool under the back cover to lift it up.
    • Pull up on the cover with your hand to release the tab holding the center of the cover in place.
  3. Lenovo Yoga 920-13IKB Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 920-13IKB Battery Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 920-13IKB Battery Replacement, Battery: passo 3, imagem 3 %32
    • Remove the four 5mm Phillips #00 screws that hold the battery in place.
  4. Lenovo Yoga 920-13IKB Battery Replacement: passo 4, imagem 1 %32 Lenovo Yoga 920-13IKB Battery Replacement: passo 4, imagem 2 %32
    • Grab the grouping of wires with your fingers close to the connector and gently pull to disconnect the battery from the motherboard.
    • The wire grouping is located underneath the thin flap near the center of the battery.
    • Do not lift the battery out before disconnection from the motherboard to prevent shortages or damage.
  5. Lenovo Yoga 920-13IKB Battery Replacement: passo 5, imagem 1 %32
    • Use the iFixit Opening Tool to lift the battery up enough to grab it with your hands.
  6. Lenovo Yoga 920-13IKB Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery.
Conclusão
30 outras pessoas executaram este guia.
Alyssa McCulloch
Membro desde: 01/24/19
1.921 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team S2-G3, White Winter 2019 Membro de Cal Poly, Team S2-G3, White Winter 2019
CPSU-WHITE-W19S2G3
Membros da 4
Autoria de 29 guias
13 comentários
What is the correct replacement battery for this device?
Stephen Prather - Responder
Simple, a real simple straight forward process with the right tools of course. Thanks
Daniel Smith - Responder
Thank you, was very easy replace battery using your guide!
Andrejs - Responder
Simple and easy. Great guide to! Thanks so much
Isaac Stahl - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 78
Últimos 30 dias: 319
Duração total: 24,492
