Ir para o conteúdo principal
Lenovo Yoga 910-13IKB Wi-Fi Card Replacement
O que você precisa
  1. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Back Panel: passo 1, imagem 2 %32
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Battery: passo 2, imagem 1 %32
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 3, imagem 1 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 3, imagem 2 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 3, imagem 3 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  4. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 4, imagem 1 %32
    • Remove the single 1 mm screw at left of Wi-Fi card with a Phillips #0 screwdriver.
  5. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Pull the Wi-Fi card out of the slot on the motherboard.
    • It is still connected to the coaxial cables so don't yank it out or those connections will break.
  6. Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 6, imagem 1 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 6, imagem 2 %32 Lenovo Yoga 910-13IKB Wi-Fi Card Replacement: passo 6, imagem 3 %32
    • Detach the white wire that is connected to the Wi-Fi card by applying gentle pressure.
    • Detach the black wire by applying gentle pressure.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 494
