Ir para o conteúdo principal
Lenovo Yoga 910-13IKB Fingerprint Reader Replacement
O que você precisa
  1. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 2, imagem 1 %32
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 3, imagem 1 %32
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 4, imagem 1 %32
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 5, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 5, imagem 2 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 5, imagem 3 %32
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 6, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 6, imagem 2 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 6, imagem 3 %32
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
  7. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Battery: passo 7, imagem 1 %32
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  8. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 8, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 8, imagem 2 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 8, imagem 3 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
  9. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Fingerprint Reader: passo 9, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement, Fingerprint Reader: passo 9, imagem 2 %32
    • Remove the one 3mm JIS #00 screw on the right side of the silver component.
  10. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 10, imagem 1 %32 Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 10, imagem 2 %32
    • Gently pull up on the ribbon cable to detach it from the metal housing.
  11. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 11, imagem 1 %32
    • Lift the metal housing out and set it aside. This component holds the reader in place.
    • The left side of the component is tucked under the lip of the computer, so lift from the right side of the component.
  12. Lenovo Yoga 910-13IKB Fingerprint Reader Replacement: passo 12, imagem 1 %32
    • Remove the fingerprint reader from its place.
Conclusão
Uma outra pessoa concluiu este guia.
Nikki Sorfleet
Membro desde: 01/23/20
166 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S1-G5, White Winter 2020 Membro de Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 416
