Ir para o conteúdo principal
Lenovo Yoga 910-13IKB Bottom Panel Replacement
O que você precisa
  1. Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Yoga 910-13IKB Bottom Panel Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 2, imagem 1 %32
    • Remove all 4 screws attached to the battery with a small Phillips head screwdriver.
    • Each screw on the back is M2 x 1.7mm
    • After the screws are taken out, remove the battery.
  3. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 3, imagem 1 %32
    • Remove all 6 screws attached to the trackpad with a small Phillips head screwdriver.
    • Detach the ribbon cable connected to the trackpad using a wedge device.
    • Remove the trackpad using a wedge device
  4. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 4, imagem 1 %32
    • Remove all 6 screws attached to the USB ports on both sides of the device with a small Philips head screwdriver.
    • Detach both ribbon cables attached to each USB port with a wedge device, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, imagem 1 %32 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, imagem 2 %32 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 5, imagem 3 %32
    • Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
    • Pull the SSD stick directly to the right until it shifts out of place to remove it.
    • The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
  6. Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, imagem 1 %32 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, imagem 2 %32 Lenovo Yoga 910-13IKB Bottom Panel Replacement: passo 6, imagem 3 %32
    • Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
    • Remove the back connector strip using a wedge device to pry it off of the device
    • With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
85.248 Reputação
Autoria de 215 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.078 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,611
