Ir para o conteúdo principal
Lenovo Yoga 900-13ISK Keyboard Replacement
O que você precisa
  1. Lenovo Yoga 900-13ISK Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 2, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 2, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Keyboard Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Battery: passo 3, imagem 3 %32
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 4, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 4, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 4, imagem 3 %32
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Keyboard Replacement, Solid State Drive: passo 5, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Solid State Drive: passo 5, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Solid State Drive: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
  6. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 6, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 6, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 6, imagem 3 %32
    • Pull the SSD card out of the port to the right.
  7. Lenovo Yoga 900-13ISK Keyboard Replacement, Wi-Fi Card Prereq: passo 7, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Wi-Fi Card Prereq: passo 7, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Wi-Fi Card Prereq: passo 7, imagem 3 %32
    • Pry up the gray and black coaxial cables from the Wi-Fi card using a spudger.
    • Move the cables to the side.
  8. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 8, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 8, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 8, imagem 3 %32
    • Using a Phillips #00 screwdriver, remove the 2.2 mm screw holding down the Wi-Fi card.
    • The Wi-Fi card may pop up to rest at an angle to the motherboard after the screw is removed.
  9. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 9, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 9, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 9, imagem 3 %32
    • Pull the WiFi card out from the connector on the motherboard.
  10. Lenovo Yoga 900-13ISK Keyboard Replacement, Motherboard: passo 10, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Motherboard: passo 10, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Motherboard: passo 10, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the pointed end of a spudger, flip up the hinged locking tabs of the eight ZIF connectors on the motherboard.
    • Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
  11. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 11, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 11, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 11, imagem 3 %32
  12. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 12, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 12, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 12, imagem 3 %32
    • Remove the five 3.6 mm screws from the motherboard using a Phillips #00 screwdriver.
  13. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 13, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 13, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 13, imagem 3 %32
    • Pull back the interconnect cable on the left side of the motherboard to reveal one of the fan screws for the left fan.
    • Remove the two 3.6 mm screws from the left fan with a Phillips #00 screwdriver.
  14. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 14, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 14, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 14, imagem 3 %32
    • Remove the two 3.6 mm screws from the right fan using a Phillips #00 screwdriver.
  15. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 15, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 15, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 15, imagem 3 %32
    • Unwind the black and white coaxial cables from the hooks on the right fan casing.
  16. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 16, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 16, imagem 2 %32
    • Lift the motherboard from the bottom edge and pull it up and out of the case.
    • If you need to remove the fan assembly to swap it over to your new motherboard, continue to follow along with the heatsink guide.
  17. Lenovo Yoga 900-13ISK Keyboard Replacement, Charging Port: passo 17, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Charging Port: passo 17, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Charging Port: passo 17, imagem 3 %32
    • Remove the two 3.5 mm screws from the charging port with a Phillips #00 screwdriver.
  18. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 18, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 18, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 18, imagem 3 %32
    • Peel up the charging port cable and remove the charging port.
  19. Lenovo Yoga 900-13ISK Keyboard Replacement, Keyboard: passo 19, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Keyboard: passo 19, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement, Keyboard: passo 19, imagem 3 %32
    • Remove the 3.6 mm screw from the daughterboard on the right with a Phillips #00 screwdriver.
  20. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 20, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 20, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 20, imagem 3 %32
    • Lift the daughterboard from the right edge and peel off the interconnect cable from the keyboard panel.
  21. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 21, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 21, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 21, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 3.6 mm screws from the daughterboard on the left.
  22. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 22, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 22, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 22, imagem 3 %32
    Comprar
    • Use a pair of blunt nose tweezers to pull out the speaker cable on the lower portion of the daughterboard.
  23. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 23, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 23, imagem 2 %32
    • Lift up the daughterboard from the right side to remove it from the case.
  24. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 24, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 24, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 24, imagem 3 %32
    • Peel back the trackpad cable from the black keyboard panel.
  25. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 25, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 25, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 25, imagem 3 %32
    • Remove the forty-one 1.9 mm screws from the keyboard panel with a Phillips #000 screwdriver.
    • While reassembling, you can use the 'X' markings to tell which holes do not need screws.
  26. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 26, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 26, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 26, imagem 3 %32
    • Open the laptop slightly.
  27. Lenovo Yoga 900-13ISK Keyboard Replacement: passo 27, imagem 1 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 27, imagem 2 %32 Lenovo Yoga 900-13ISK Keyboard Replacement: passo 27, imagem 3 %32
    • Press the keyboard up from the underside and grab it to remove it from the case.
Conclusão
3 outras pessoas executaram este guia.
Austin Blakely
Membro desde: 03/11/19
19.855 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 1,659
