Ir para o conteúdo principal
Lenovo Yoga 900-13ISK Display Assembly Replacement
O que você precisa
  1. Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 2, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 2, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 2, imagem 3 %32
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement, Battery: passo 3, imagem 3 %32
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 4, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 4, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 4, imagem 3 %32
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: passo 5, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement, Display Assembly: passo 5, imagem 3 %32
    • Remove the ten 3.6 mm screws from the hinge bracket with a Phillips #00 screwdriver.
  6. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 6, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 6, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 6, imagem 3 %32
    • Use the pointed end of a spudger to lift the hinged locking flap of the display ZIF connector.
  7. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 7, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull out the display cable with a pair of blunt nose tweezers.
  8. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 8, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 8, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 8, imagem 3 %32
    • Open the laptop to a 45° angle, then close the laptop.
    • This raises the hinge, which will stay open as the bottom case is lowered.
  9. Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 9, imagem 1 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 9, imagem 2 %32 Lenovo Yoga 900-13ISK Display Assembly Replacement: passo 9, imagem 3 %32
    • Slide the bottom case away from the hinge.
    • If the hinge is catching on the case, either go back to the previous step and open the case a bit more, or manually open the hinge with your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Blakely
Membro desde: 03/11/19
19.955 Reputação
Autoria de 53 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.078 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Duração total: 904
