Ir para o conteúdo principal
Lenovo Yoga 730-13IKB Storage Replacement
O que você precisa
  1. Lenovo Yoga 730-13IKB Storage Replacement, Back Case: passo 1, imagem 1 %32 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: passo 1, imagem 2 %32 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: passo 1, imagem 3 %32
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Storage Replacement: passo 2, imagem 1 %32 Lenovo Yoga 730-13IKB Storage Replacement: passo 2, imagem 2 %32 Lenovo Yoga 730-13IKB Storage Replacement: passo 2, imagem 3 %32
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Storage Replacement: passo 3, imagem 1 %32
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Storage Replacement, Storage: passo 4, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 4mm screw holding down the storage drive.
  5. Lenovo Yoga 730-13IKB Storage Replacement: passo 5, imagem 1 %32 Lenovo Yoga 730-13IKB Storage Replacement: passo 5, imagem 2 %32
    • Hold onto the back of the storage drive and slightly lift up.
    • Remove the drive by pulling back at a diagonal angle.
    • To install the storage drive, insert it into the connector at a slight downwards angle. The drive connector is keyed and will only go in one way.
Conclusão
Uma outra pessoa concluiu este guia.
Colin Reay
Membro desde: 01/23/20
848 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S1-G1, White Winter 2020 Membro de Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 31
Duração total: 1,461
