Ir para o conteúdo principal
Lenovo Yoga 720-15IKB Battery Replacement
O que você precisa
  1. Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, imagem 2 %32 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Battery Replacement: passo 2, imagem 1 %32 Lenovo Yoga 720-15IKB Battery Replacement: passo 2, imagem 2 %32
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 720-15IKB Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  4. Lenovo Yoga 720-15IKB Battery Replacement: passo 4, imagem 1 %32 Lenovo Yoga 720-15IKB Battery Replacement: passo 4, imagem 2 %32
    • Pull firmly on the battery connector to disconnect it.
  5. Lenovo Yoga 720-15IKB Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the case to remove it.
Conclusão
10 outras pessoas executaram este guia.
Matthew Bornhorst
Membro desde: 01/23/20
495 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S19-G3, White Winter 2020 Membro de Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
Membros da 4
Autoria de 25 guias
3 comentários
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
James Smith - Responder
Good guide. Fairly easy project. Getting the battery connector back in on the replacement battery was by far the hardest part. Be patient with it. It took me a few tries, but it slid in fairly easily once it was all lined up correctly.
Mark Haakenson - Responder
Thank you for the great informative guide! ordering my battery and tools now!
justmelendez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 63
Últimos 30 dias: 258
Duração total: 11,853
