Ir para o conteúdo principal
Lenovo Yoga 720-12IKB Wireless LAN Card Replacement
O que você precisa
  1. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 2, imagem 1 %32
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 3, imagem 1 %32 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 3, imagem 2 %32
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 4, imagem 1 %32 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 4, imagem 2 %32
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 5, imagem 1 %32
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement, Wireless LAN Card: passo 6, imagem 1 %32
    • On the top right of the system you will find the wireless LAN card. Remove the 3.0 mm Phillips #00 screw.
  7. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 7, imagem 1 %32 Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 7, imagem 2 %32
    • Disconnect both wireless LAN cables by pulling up.
  8. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 8, imagem 1 %32
    • Lift the wireless LAN card up and pull out.
  9. Lenovo Yoga 720-12IKB Wireless LAN Card Replacement: passo 9, imagem 1 %32
    • You can now replace the wireless LAN card.
Conclusão
Alex Escobar
Membro desde: 02/10/22
778 Reputação
Autoria de 6 guias
Equipe
Gateway, Team 1-4, Pee Spring 2022 Membro de Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 148
