Ir para o conteúdo principal
Lenovo Yoga 720-12IKB Motherboard Replacement
O que você precisa
  1. Lenovo Yoga 720-12IKB Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew and remove the four 5.5 mm Phillips #00 screws on the back panel.
  2. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 2, imagem 1 %32
    • Pull down on the cover to remove it and you will see the battery after removing the cover.
  3. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Yoga 720-12IKB Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew and remove the 4.0 mm Phillips #00 screws on the battery to remove it from the motherboard.
  4. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Yoga 720-12IKB Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the battery wires from the socket on the motherboard above the battery.
  5. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 5, imagem 1 %32
    • Finally remove the battery from the case.
  6. Lenovo Yoga 720-12IKB Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • The motherboard is located above the battery.
  7. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 7, imagem 1 %32
    • Unscrew and remove the 2.0 mm Phillips #00 screws.
  8. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Yoga 720-12IKB Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the connectors by lifting up the clip and pulling them out.
  9. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the 4.0 mm Phillips #00 screws from the fan.
    • Remove the 4.0 mm Phillips #00 screws from the heatsink.
  10. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 10, imagem 1 %32 Lenovo Yoga 720-12IKB Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the 5.5 mm Phillips #00 screws from the hinge.
    • Remove the 4.0 mm Phillips #00 screws froom the hinge.
    • Open the laptop a little to lift the hinge.
  11. Lenovo Yoga 720-12IKB Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the motherboard after all screws are out and connectors are disconnected.
Conclusão
Alex Escobar
Membro desde: 02/10/22
778 Reputação
Autoria de 6 guias
Equipe
Gateway, Team 1-4, Pee Spring 2022 Membro de Gateway, Team 1-4, Pee Spring 2022
GCC-PEE-S22S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 391
