Introdução
This guide will show you how to replace the speakers.
O que você precisa
Ferramenta utilizada nesse passo:JIS Driver Set$19.99
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
5 outras pessoas executaram este guia.
