Ir para o conteúdo principal
Lenovo Yoga 720 Bottom Cover Replacement
O que você precisa
  1. Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 2 %32 Lenovo Yoga 720 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    T5 Torx Screwdriver
    $5.49
    Comprar
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Bottom Cover Replacement: passo 2, imagem 1 %32 Lenovo Yoga 720 Bottom Cover Replacement: passo 2, imagem 2 %32 Lenovo Yoga 720 Bottom Cover Replacement: passo 2, imagem 3 %32
    iFixit Opening Tool
    $1.99
    Comprar
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Bottom Cover Replacement: passo 3, imagem 1 %32 Lenovo Yoga 720 Bottom Cover Replacement: passo 3, imagem 2 %32 Lenovo Yoga 720 Bottom Cover Replacement: passo 3, imagem 3 %32
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
Conclusão
5 outras pessoas executaram este guia.
Aiden
Membro desde: 09/19/15
17.564 Reputação
Autoria de 21 guias
Um comentário
Can’t seem to find information about this but why should I discharge the laptop to 25% before I do this?
I bought a new wifi card that I will put in.
Björn Ridell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 7,432
