Introdução
This guide will show you how to replace the speakers in a Lenovo Yoga 710-15ISK laptop. The speakers are not necessary for your laptop to function but are a nice feature to have as they allow sound to be produced without the assistance of headphones. Signs your speakers may need to be replaced are hissing, fuzz, and static sounds being produced at normal volume levels and getting worse when the volume is increased. Remember that you can plug external speakers or headphones into your laptop’s 3.5mm jack before you finish your speaker replacement to continue to have sound.
O que você precisa
Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
Disconnect the speaker wires from the motherboard by gently pulling the white connector from its port.
