Ir para o conteúdo principal
Lenovo Yoga 710-15ISK Motherboard Replacement
O que você precisa
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 2, imagem 1 %32
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: passo 6, imagem 1 %32
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 7, imagem 1 %32
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 8, imagem 2 %32
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: passo 9, imagem 1 %32
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 10, imagem 1 %32 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 11, imagem 1 %32
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, imagem 1 %32 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, imagem 2 %32 Lenovo Yoga 710-15ISK Motherboard Replacement: passo 13, imagem 3 %32
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: passo 14, imagem 1 %32
    • Carefully lift out the motherboard to remove it from the laptop.
Conclusão
Annette Limoges
Membro desde: 10/25/21
181 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Membro de UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 286
