Ir para o conteúdo principal
Lenovo Yoga 710-15IKB Solid State Drive Replacement
O que você precisa
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 2, imagem 1 %32
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 3, imagem 1 %32
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 4, imagem 1 %32
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 6, imagem 1 %32
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: passo 7, imagem 1 %32
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: passo 8, imagem 1 %32
    • Gently pull the solid state drive out and up to remove it from the connector.
Conclusão
3 outras pessoas executaram este guia.
Andrew Keenan
Membro desde: 11/30/17
173 Reputação
Autoria de 1 guia
Equipe
Um comentário
No need to remove battery. No need for tweezers.
Shane Whittet - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Duração total: 7,063
