Ir para o conteúdo principal
Lenovo Yoga 710-15IKB Fan Replacement
O que você precisa
  1. Lenovo Yoga 710-15IKB Fan  Replacement, Battery: passo 1, imagem 1 %32
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Fan  Replacement: passo 2, imagem 1 %32
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Fan  Replacement: passo 3, imagem 1 %32
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Fan  Replacement: passo 4, imagem 1 %32
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Fan  Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Fan  Replacement: passo 6, imagem 1 %32
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Fan  Replacement, Fan: passo 7, imagem 1 %32
    Comprar
    • Use tweezers to grab the fan harness.
    • Gently pull the harness to disconnect from motherboard.
  8. Lenovo Yoga 710-15IKB Fan  Replacement: passo 8, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four screws holding down the fans.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 2,171
