Ir para o conteúdo principal
Lenovo Yoga 710-15IKB Back Cover Replacement
O que você precisa
  1. Lenovo Yoga 710-15IKB Back Cover Replacement, Lenovo Yoga 710-15IKB Back Cover Replacement: passo 1, imagem 1 %32
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Back Cover Replacement: passo 2, imagem 1 %32
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Back Cover Replacement: passo 3, imagem 1 %32
    • Lift the back cover.
Conclusão
4 outras pessoas executaram este guia.
Equipe
2 comentários
Hello,
i am looking for lenovo yoga 710 15” laptop lcd and top body part, where lcd fixed. please suggest.
Thanks & Regards,
Vilas
salvivilas@gmail.com
sunilkedar - Responder
You can get the screens for these fairly easily online, the only problem is the special command adhesive that goes with it doesn’t exist. I have been struggling to get this screen to stick using the recommended 3m adhesive alternative. The screen just wont stick! It appears to stick for weeks without issue but eventually this fails.
service - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 3,198
