Ir para o conteúdo principal
Lenovo Yoga 710-14IKB Wi-Fi Card Replacement
O que você precisa
  1. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 2, imagem 2 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 1 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 2 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Peel off the black tape covering the top of the WiFi card.
    • Remove the black and white antenna cable attached to the card by pulling them off using the precison tweezers.
    • BE CAREFUL! The antenna socket is VERY FRAGILE. If you use brute force, the antenna socket on board (female) will be pull out with the male connector.
    • If you disconnect the antenna cable properly, the socket will remain undamaged like fig.3
  4. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 4, imagem 1 %32
    • If you disconnect it with brute force, it will be damaged like that.
  5. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 5, imagem 1 %32
    • Use a #00 Phillips screwdriver to remove the 3mm screw in the center at the top of the card.
  6. Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 6, imagem 1 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 6, imagem 2 %32 Lenovo Yoga 710-14IKB Wi-Fi Card Replacement: passo 6, imagem 3 %32
    • The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket.
Conclusão
7 outras pessoas executaram este guia.
Grant Doerksen
Membro desde: 04/17/17
1.005 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S14-G5, Banghart Spring 2017 Membro de Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
Membros da 4
Autoria de 27 guias
Um comentário
I haven’t done it yet, but I’m no longer worried in the slightest! Your guide is about as dummy friendly as it gets, and I cannot even tell you how helpful your detailed instructions, ALONG WITH EXACT, CLEAR, and zoom-able pics of every step , PLUS warnings of what NOT to do and how to tell if you’ve screwed it up!!! A breath of fresh air compared what I’ve come to expect anymore online. I get ones like this - a super fast video, cam behind the person, too far away to see what they’re doing & how; The only zoomed-in shots are the before & after; No talking just background music ; Then in the description, where you expect their instructions, you get only stupidity… ie, like, “open laptop, remove wifi card.Put new one in the same way”. Wow, no sh**?! Idiots… Sadly, not exaggerated! So I just had to thank you, this is how it’s DONE! People should follow your example, something might get done (and done right) for a change!! Keep up the good work if this is ur thing! If not, it should be! Thanks again!
Teresa Allton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 3,610
