Ir para o conteúdo principal
Lenovo Yoga 710-14IKB Trackpad Replacement
O que você precisa
  1. Lenovo Yoga 710-14IKB Trackpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 2, imagem 1 %32 Lenovo Yoga 710-14IKB Trackpad Replacement: passo 2, imagem 2 %32 Lenovo Yoga 710-14IKB Trackpad Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 4, imagem 1 %32 Lenovo Yoga 710-14IKB Trackpad Replacement: passo 4, imagem 2 %32
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Trackpad Replacement, Trackpad: passo 6, imagem 1 %32
    • Use the Phillips #1 screwdriver to take off the three 3mm screws.
  7. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 7, imagem 1 %32 Lenovo Yoga 710-14IKB Trackpad Replacement: passo 7, imagem 2 %32
    • Grip the blue tab and pull out.
    • Careful to not pull too hard, there is a chance of damaging the tab.
  8. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 8, imagem 1 %32 Lenovo Yoga 710-14IKB Trackpad Replacement: passo 8, imagem 2 %32
    • Lift off the layer of tape from the trackpad.
  9. Lenovo Yoga 710-14IKB Trackpad Replacement: passo 9, imagem 1 %32
    • Push out the trackpad.
Conclusão
Uma outra pessoa concluiu este guia.
Chuefeng Vang
Membro desde: 11/01/18
136 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,429
