Introdução
This simple guide will show you how to remove the two speakers from a Lenovo Yoga 710-14KB.
O que você precisa
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
Locate the speaker's plug and disconnect it.
Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
Quase terminado!
Conclusão
