Ir para o conteúdo principal
Lenovo Yoga 710-14IKB RAM Replacement
O que você precisa
  1. Lenovo Yoga 710-14IKB RAM Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB RAM Replacement: passo 2, imagem 1 %32 Lenovo Yoga 710-14IKB RAM Replacement: passo 2, imagem 2 %32 Lenovo Yoga 710-14IKB RAM Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB RAM Replacement, RAM: passo 3, imagem 1 %32 Lenovo Yoga 710-14IKB RAM Replacement, RAM: passo 3, imagem 2 %32
    • Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
  4. Lenovo Yoga 710-14IKB RAM Replacement: passo 4, imagem 1 %32 Lenovo Yoga 710-14IKB RAM Replacement: passo 4, imagem 2 %32
    • Locate the ram hold downs.
    • Push outwards on the hold downs to release the RAM.
    una pregunta, cuantas ranuras de memoria RAM tiene?
    One question, how many RAM slots does it have?
    andres arce - Responder
  5. Lenovo Yoga 710-14IKB RAM Replacement: passo 5, imagem 1 %32 Lenovo Yoga 710-14IKB RAM Replacement: passo 5, imagem 2 %32
    • Remove the RAM by pulling away from the RAM socket.
    Thanks, updated to 16GB, works fine!!!
    Roman Hrytsiuk - Responder
Conclusão
14 outras pessoas executaram este guia.
Grant Doerksen
Membro desde: 04/17/17
1.005 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S14-G5, Banghart Spring 2017 Membro de Cal Poly, Team S14-G5, Banghart Spring 2017
CPSU-BANGHART-S17S14G5
Membros da 4
Autoria de 21 guias
4 comentários
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
victoria - Responder
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
Johannes de Wit -
It has 1 RAM slot
Lil Youman -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 47
Duração total: 6,445
