Ir para o conteúdo principal
Lenovo Yoga 710-14IKB Motherboard Replacement
O que você precisa
  1. Lenovo Yoga 710-14IKB Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement: passo 2, imagem 2 %32 Lenovo Yoga 710-14IKB Motherboard Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement: passo 4, imagem 2 %32
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: passo 6, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  7. Lenovo Yoga 710-14IKB Motherboard Replacement: passo 7, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement: passo 7, imagem 2 %32
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
  8. Lenovo Yoga 710-14IKB Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Use a PH00 screwdriver to remove the nine 3mm screws.
  9. Lenovo Yoga 710-14IKB Motherboard Replacement: passo 9, imagem 1 %32 Lenovo Yoga 710-14IKB Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the indicated cables from the motherboard.
    • Be careful when removing cables. Do not pull or yank cables from their slots.
    • Remove the motherboard.
    • If you want to fully remove the motherboard, you must desolder the display cable.
Conclusão
3 outras pessoas executaram este guia.
Evan Cruzen
Membro desde: 11/01/18
253 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Membro de UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 2,884
