Introdução
If your device isn’t properly registering clicks or cursor movements, the trackpad may be faulty. Follow these instructions to remove and replace the trackpad in your Lenovo Yoga 710-11ISK.
Peças
Nenhum componente especificado.
Flip the device having the bottom panel facing you.
Remove the eleven 5mm Torx T5 screws from the back panel.
Using a Phillips #00 screwdriver, remove the three 3mm screws located at the top of the trackpad.
Quase terminado!
Conclusão
