Ir para o conteúdo principal
Lenovo Yoga 710-11ISK Speaker Replacement
O que você precisa
  1. Lenovo Yoga 710-11ISK Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the 11 screws located on the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Speaker Replacement: passo 2, imagem 1 %32
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Speaker Replacement: passo 3, imagem 1 %32 Lenovo Yoga 710-11ISK Speaker Replacement: passo 3, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Grip the battery cable connector on both sides of the plug and gently pull it directly from its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Speaker Replacement: passo 4, imagem 1 %32
    • Unplug the wire harness on the left side of the computer to disconnect the speakers from the motherboard
    • Remove the white and blue wires from the plastic brackets holding them in place.
  5. Lenovo Yoga 710-11ISK Speaker Replacement: passo 5, imagem 1 %32 Lenovo Yoga 710-11ISK Speaker Replacement: passo 5, imagem 2 %32 Lenovo Yoga 710-11ISK Speaker Replacement: passo 5, imagem 3 %32
    • Carefully remove both speakers and rubber grommets from their mounts.
    • Slide the right speaker underneath the white ribbon wire.
    • Lift the speakers up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 93
