Introdução
This guide shows how to replace the RAM for the Lenovo Yoga 710-11ISK. This will need to be done if you notice Apps are running slowly and you have frequent crashes.
In order to complete this guide, you’ll need to know how to solder connections and joints. Please follow the How to Solder and Desolder Connections guide for more information on soldering.
O que você precisa
Make sure back panel is facing up.
Remove eleven 5mm screws with the T5 Torx Screwdriver.
Using a soldering iron, unsolder the joints connecting the RAM.
Remove the RAM from the device.
Quase terminado!
Conclusão
