Ir para o conteúdo principal
Lenovo Yoga 710-11ISK Motherboard Replacement
O que você precisa
  1. Lenovo Yoga 710-11ISK Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the eleven screws that attach the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 2, imagem 1 %32
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 3, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Hold the cable connector on both sides and gently pull it directly out of its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 4, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the eight screws securing the motherboard, Wi-Fi card, and SSD card.
    • Unplug the Wi-Fi and SSD cards from the motherboard along with the attached wire harnesses.
  5. Lenovo Yoga 710-11ISK Motherboard Replacement: passo 5, imagem 1 %32 Lenovo Yoga 710-11ISK Motherboard Replacement: passo 5, imagem 2 %32
    • Lift the motherboard up and out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 192
