Ir para o conteúdo principal
Lenovo Yoga 3 Pro Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Lenovo Yoga 3 Pro Motherboard Replacement: passo 2, imagem 1 %32
    • Gently lift the back cover off of the laptop.
  3. Lenovo Yoga 3 Pro Motherboard Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Push the black battery cable towards the battery to disconnect it.
  4. Lenovo Yoga 3 Pro Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Lenovo Yoga 3 Pro Motherboard Replacement: passo 5, imagem 1 %32
    • Gently lift the battery out of the laptop chassis.
  6. Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: passo 6, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: passo 6, imagem 2 %32
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  7. Lenovo Yoga 3 Pro Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  8. Lenovo Yoga 3 Pro Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 8, imagem 2 %32
    • Gently lift and pull the wifi card out.
  9. Lenovo Yoga 3 Pro Motherboard Replacement, SSD: passo 9, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement, SSD: passo 9, imagem 2 %32
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  10. Lenovo Yoga 3 Pro Motherboard Replacement: passo 10, imagem 1 %32
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
  11. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: passo 11, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: passo 11, imagem 3 %32
    • Push the cable away from the motherboard.
  12. Lenovo Yoga 3 Pro Motherboard Replacement: passo 12, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 12, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the two #0 2.9mm Phillips screws from the daughter board.
  13. Lenovo Yoga 3 Pro Motherboard Replacement: passo 13, imagem 1 %32
    • Lift the daughter board with the plastic opening tool.
    • You will hear two clicks when lifting the daughter board.
  14. Lenovo Yoga 3 Pro Motherboard Replacement: passo 14, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 14, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 14, imagem 3 %32
    • Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
  15. Lenovo Yoga 3 Pro Motherboard Replacement: passo 15, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 15, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 15, imagem 3 %32
    • Gently lift the metal tabs on the daughter board to free the wires.
  16. Lenovo Yoga 3 Pro Motherboard Replacement: passo 16, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 16, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 16, imagem 3 %32
    • Detach the five flat flex cables attached to the motherboard as follows:
    • 1. Flip the cable holder up with a finger nail
    • 2. Pull on the tab to remove the cable.
    • The large black flat flex labeled 'MB' does not have a tab so gently tug the cable free from the end after flipping the cable holder.
  17. Lenovo Yoga 3 Pro Motherboard Replacement: passo 17, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 17, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 17, imagem 3 %32
    • Remove the four #0 2.3mm Phillips screws holding down the motherboard.
    • Remove the two #0 2.9mm Phillips screws holding down the fan.
  18. Lenovo Yoga 3 Pro Motherboard Replacement: passo 18, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 18, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 18, imagem 3 %32
    • Make sure the motherboard and fan are not caught on anything when flipping it over.
    • Gently lift and flip the motherboard over.
  19. Lenovo Yoga 3 Pro Motherboard Replacement: passo 19, imagem 1 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 19, imagem 2 %32 Lenovo Yoga 3 Pro Motherboard Replacement: passo 19, imagem 3 %32
    • Flip the cable lock holding down the monitor connector.
    • Remove the monitor connector by tugging on the tab.
Conclusão
5 outras pessoas executaram este guia.
Nathan Lui
Membro desde: 04/10/17
839 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S13-G6, Forte Spring 2017 Membro de Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
Membros da 4
Autoria de 12 guias
2 comentários
There is a tremendous difference between this model and the lenovo yoga 4 900-13ISK.
These instructions do not apply, but some steps are similar
corey - Responder
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
Martin Loffler - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 7,689
