Ir para o conteúdo principal
Lenovo Yoga 3 14 USB Port Replacement
O que você precisa
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: passo 2, imagem 1 %32 Lenovo Yoga 3 14 USB Port Replacement: passo 2, imagem 2 %32 Lenovo Yoga 3 14 USB Port Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: passo 3, imagem 1 %32
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: passo 4, imagem 1 %32 Lenovo Yoga 3 14 USB Port Replacement: passo 4, imagem 2 %32 Lenovo Yoga 3 14 USB Port Replacement: passo 4, imagem 3 %32
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: passo 5, imagem 1 %32 Lenovo Yoga 3 14 USB Port Replacement, USB Port: passo 5, imagem 2 %32
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: passo 6, imagem 1 %32 Lenovo Yoga 3 14 USB Port Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: passo 7, imagem 1 %32
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
Conclusão
Matthew Victores
Membro desde: 09/28/16
602 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 3-2, Passmore Fall 2016 Membro de USF Tampa, Team 3-2, Passmore Fall 2016
USFT-PASSMORE-F16S3G2
Membros da 4
Autoria de 7 guias
2 comentários
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 2,130
