Introdução
If you are experiencing any problems with your laptop dying quickly when it is not plugged into an outlet, You might need to replace the battery of your laptop. The battery is what gives your laptop power when it is not plugged. The following guide will show you how to replace the battery.
O que você precisa
5 outras pessoas executaram este guia.
Um comentário
Hello… Thanks for this guide… can u help me locate the CMOS battery on this device. Regards
