Ir para o conteúdo principal
Lenovo Yoga 3 11 Trackpad Replacement
O que você precisa
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: passo 2, imagem 1 %32 Lenovo Yoga 3 11 Trackpad Replacement, Battery: passo 2, imagem 2 %32 Lenovo Yoga 3 11 Trackpad Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: passo 3, imagem 1 %32
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: passo 4, imagem 1 %32 Lenovo Yoga 3 11 Trackpad Replacement: passo 4, imagem 2 %32
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: passo 5, imagem 1 %32
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: passo 7, imagem 1 %32
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: passo 8, imagem 1 %32 Lenovo Yoga 3 11 Trackpad Replacement: passo 8, imagem 2 %32
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: passo 9, imagem 1 %32 Lenovo Yoga 3 11 Trackpad Replacement: passo 9, imagem 2 %32
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
Conclusão
Uma outra pessoa concluiu este guia.
Slade Fernandes
Membro desde: 08/27/15
532 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2015 Membro de USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
Membros da 4
Autoria de 11 guias
Um comentário
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,822
