Ir para o conteúdo principal
Lenovo Yoga 3 11 Speaker Replacement
O que você precisa
  1. Lenovo Yoga 3 11 Speaker Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Speaker Replacement, Battery: passo 2, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement, Battery: passo 2, imagem 2 %32 Lenovo Yoga 3 11 Speaker Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Speaker Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Speaker Replacement: passo 4, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement: passo 4, imagem 2 %32
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Speaker Replacement: passo 5, imagem 1 %32
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Speaker Replacement, Speaker: passo 6, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement, Speaker: passo 6, imagem 2 %32
    Comprar
    • Use a pair of tweezers to peel up one side of each of the 3 pieces of tape that cover the speaker wires.
  7. Lenovo Yoga 3 11 Speaker Replacement: passo 7, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement: passo 7, imagem 2 %32
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift the black tab up, and the cable should come free.
  8. Lenovo Yoga 3 11 Speaker Replacement: passo 8, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement: passo 8, imagem 2 %32 Lenovo Yoga 3 11 Speaker Replacement: passo 8, imagem 3 %32
    • Remove the two 2 mm Phillips #0 screws securing the left speaker.
    • Remove the two 2 mm Phillips #0 screws securing the right speaker.
  9. Lenovo Yoga 3 11 Speaker Replacement: passo 9, imagem 1 %32 Lenovo Yoga 3 11 Speaker Replacement: passo 9, imagem 2 %32
    • Use a pair of tweezers to disconnect the speaker connector.
    • Gently lift the speakers free of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Slade Fernandes
Membro desde: 08/27/15
532 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2015 Membro de USF Tampa, Team 2-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G3
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,226
