Ir para o conteúdo principal
Lenovo Yoga 3 11 SSD Replacement
O que você precisa
  1. Lenovo Yoga 3 11 SSD Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 SSD Replacement, Battery: passo 2, imagem 1 %32 Lenovo Yoga 3 11 SSD Replacement, Battery: passo 2, imagem 2 %32 Lenovo Yoga 3 11 SSD Replacement, Battery: passo 2, imagem 3 %32
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 SSD Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 SSD Replacement: passo 4, imagem 1 %32 Lenovo Yoga 3 11 SSD Replacement: passo 4, imagem 2 %32
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 SSD Replacement: passo 5, imagem 1 %32
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 SSD Replacement, SSD: passo 6, imagem 1 %32
    Comprar
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 SSD Replacement: passo 7, imagem 1 %32
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 SSD Replacement: passo 8, imagem 1 %32
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 SSD Replacement: passo 9, imagem 1 %32
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 SSD Replacement: passo 10, imagem 1 %32
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 SSD Replacement: passo 11, imagem 1 %32 Lenovo Yoga 3 11 SSD Replacement: passo 11, imagem 2 %32
    • Remove the single 2 mm Phillips #00 screw securing the SSD.
    • Gently lift the SSD up and out of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Geoff Wacker
Membro desde: 09/30/13
90.313 Reputação
Autoria de 89 guias
4 comentários
Perché non posso passare direttamente dallo step 2 allo step 11 ?
Keyman - Responder
Same(ish) question as Keyman: why not steps 1, possibly 3, then 11? Why disconnect everything if the SSD is fully exposed when the bottom comes off?
ifaxit - Responder
Basta infatti scollegare la batteria per evitare eventuali ritorni di massa prima di sostituire l'ssd
IRREAL - Responder
he thought that was ram and drilled further to find the ssd perhaps.
furterers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 37
Duração total: 9,855
