Introdução
Use this guide to replace the SSD in your Lenovo Yoga 3 11.
Peças
Nenhum componente especificado.
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
Uma outra pessoa concluiu este guia.
