Ir para o conteúdo principal
Lenovo Yoga 2 Pro Wireless Card Replacement
O que você precisa
  1. Lenovo Yoga 2 Pro Wireless Card Replacement, Wireless Card: passo 1, imagem 1 %32
    • Please ensure that the laptop is turned off before beginning.
    • Using a T5 Torx screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 2, imagem 1 %32
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 3, imagem 1 %32
    • Locate the wireless module above the battery in the top left corner of the computer.
    • Using a spudger, disconnect the two metal connectors by popping the metal piece up from the wireless module.
  4. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 4, imagem 1 %32
    • Remove the one 1/16” screw using a Phillips #00 screwdriver.
  5. Lenovo Yoga 2 Pro Wireless Card Replacement: passo 5, imagem 1 %32 Lenovo Yoga 2 Pro Wireless Card Replacement: passo 5, imagem 2 %32
    • Slide the wireless module towards the battery and lift out of the laptop.
Conclusão
9 outras pessoas executaram este guia.
Thomas Simko
Membro desde: 10/01/15
2.531 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-14, Maness Fall 2015 Membro de Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
Membros da 5
Autoria de 12 guias
2 comentários
Be careful, there is a very restrictive Whitelist in the BIOS for potential replacements, unofficial support available via their forums;
(tl;dr - go with Intel AC 7260 - m.2 connection)
https://forums.lenovo.com/t5/Lenovo-Yoga...
Jamie Haustead - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 11,280
