Ir para o conteúdo principal
Lenovo Yoga 2 Pro SSD Replacement
O que você precisa
  1. Lenovo Yoga 2 Pro SSD Replacement, SSD: passo 1, imagem 1 %32
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro SSD Replacement: passo 2, imagem 1 %32
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro SSD Replacement: passo 3, imagem 1 %32
    • Navigate to the top right corner of the laptop and locate the solid state drive next to the fan.
    • Using a Phillips #00 screwdriver, remove the one 3/16” screw from the top left corner of the solid state drive.
    • The solid state drive will lift up after you remove the screw.
  4. Lenovo Yoga 2 Pro SSD Replacement: passo 4, imagem 1 %32 Lenovo Yoga 2 Pro SSD Replacement: passo 4, imagem 2 %32
    • To remove the solid state drive, gently slide it away from the battery and towards the hinges.
Conclusão
24 outras pessoas executaram este guia.
Thomas Simko
Membro desde: 10/01/15
2.531 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-14, Maness Fall 2015 Membro de Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
Membros da 5
Autoria de 12 guias
7 comentários
Thanks for the clarity of the presentation. I am having difficulty with Lenovo identifying and purchasing a 256 GB replacement SSD for my yoga pro 2 laptop. Any suggestions about what the specs of that drive might be and where I can find one would be most appreciated.
Charles Wantman - Responder
That looks like an M.2? I’m trying to figure that out myself, I’ll let you know if I find out.
Amethyst O'Connell -
Did you find it?  I would go to Amazon with part number mz-m5e250bw (it’s a Samsung card) … you don’t have to buy there.
I had to use a Torque #5 for the eleven screws on the back … the #00 Phillips was perfect for the SSD card itself.
jo diamond - Responder
How do you put the new one in? By reversing the process?
Lauren Neal - Responder
I am trying to find a reader for this old SSD. I purchased a M.2 NVME SATA SSD Enclosure Adapter, which I thought would work as a SATA PCIe M-Key(B+M Key) ssd reader but it doesn’t fit. Anyone point me towards a correct adapter?
YonA Dabs - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 132
Duração total: 33,227
