Introdução
This guide will explain how to safely remove the screen from your Lenovo Yoga 2 13" laptop. It will provide a list of the tools needed as well as the easiest way to remove the screen without damaging it.
O que você precisa
Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
11 outras pessoas executaram este guia.
3 comentários
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
