Ir para o conteúdo principal
Lenovo Yoga 2 13" Keyboard Keys Replacement
O que você precisa
  1. Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: passo 1, imagem 1 %32 Lenovo Yoga 2 13" Keyboard Keys Replacement, Keyboard Keys: passo 1, imagem 2 %32
    • Using a flat tool, carefully jimmy the selected key until it pops out.
  2. Lenovo Yoga 2 13" Keyboard Keys Replacement: passo 2, imagem 1 %32
    • To insert a new key, simply place and apply pressure until it snaps into place.
Conclusão
Uma outra pessoa concluiu este guia.
Nichelle
Membro desde: 03/11/15
1.550 Reputação
Autoria de 5 guias
Equipe
Marist, Team 1-2, Laflen Spring 2015 Membro de Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
Membros da 3
Autoria de 7 guias
4 comentários
this doesn't fix a non-working electric contact, does it?
Simon - Responder
I came across this page since my Yoga 2 Pro had 2 keys that didn't press down very well. Instead of fully removing the keys, I used a flat tool to pry up the key a little bit, then used compressed air to clean out under the keys. I had to do this a few times from a few different angels, but it finally worked
and the keys feel like normal again.
a.adler55 - Responder
Does this break the old keys so that you must replace them or is it possible to insert the same ones again?
Johannes Scheller - Responder
For those who found this page in 2022, I’ll answer the old questions so you don’t have to look elsewhere.
This does not fix a non-working electrical contact, this is just for replacing the top.
Secondly no it does not break the old key if you do it carefully.
Kind Regards
Lost Yogi
Lost Yogi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 17,539
