Ir para o conteúdo principal
Lenovo Yoga 2 13" Fan Replacement
O que você precisa
  1. Lenovo Yoga 2 13" Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Fan Replacement: passo 2, imagem 1 %32
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Fan Replacement, Fan: passo 3, imagem 1 %32
    • Locate the fan near the top of the laptop.
  4. Lenovo Yoga 2 13" Fan Replacement: passo 4, imagem 1 %32
    • Carefully unscrew three 2.381mm screws using a Phillips head screwdriver.
  5. Lenovo Yoga 2 13" Fan Replacement: passo 5, imagem 1 %32
    • The fan is attatched to four wires and a white clip. Carefully slide the clip out of the yellow port to completely remove the fan.
Conclusão
13 outras pessoas executaram este guia.
Nichelle
Membro desde: 03/11/15
1.550 Reputação
Autoria de 5 guias
Equipe
Marist, Team 1-2, Laflen Spring 2015 Membro de Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
Membros da 3
Autoria de 7 guias
3 comentários
Anyone know where I can buy a replacement fan? I'm having a hard time finding the correct model. I have a first generation Thinkpad Yoga.
Daniel Shen - Responder
where can i find a new fan for lenovo yoga 2 13
peter trevisan - Responder
where can i find a new lenovo yoga 2 13?
Han Altae-Tran - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 14,085
