Ir para o conteúdo principal
Lenovo Yoga 2 13" Battery Replacement
O que você precisa
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: passo 2, imagem 1 %32
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: passo 3, imagem 1 %32
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: passo 4, imagem 1 %32
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: passo 6, imagem 1 %32
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
Conclusão
12 outras pessoas executaram este guia.
Nichelle
Membro desde: 03/11/15
1.550 Reputação
Autoria de 5 guias
Equipe
Marist, Team 1-2, Laflen Spring 2015 Membro de Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 58
Duração total: 31,283
