Ir para o conteúdo principal
Lenovo Yoga 2 11" Back Panel Replacement
O que você precisa
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: passo 2, imagem 1 %32
    • Carefully separate back panel from laptop.
Conclusão
3 outras pessoas executaram este guia.
Peyton Leeson
Membro desde: 10/01/15
939 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 4-3, Maness Fall 2015 Membro de Cal Poly, Team 4-3, Maness Fall 2015
CPSU-MANESS-F15S4G3
Membros da 4
Autoria de 5 guias
3 comentários
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Responder
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Responder
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 4,700
