Introdução
This guide will show to how to properly remove and replace the touchpad of a Lenovo Yoga 2 11 “ with the serial number 20428.
O que você precisa
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Remove the six 3.3 mm Phillips #000 screws around the perimeter of the battery.
Remove the single 6.75 mm Phillips #000 screw from the center of the battery.
Quase terminado!
Conclusão
Um comentário
Correction to the tools needed. The screws for the bottom panel are T5 Torx, not T4 Torx. T4 will strip the screws.
