Ir para o conteúdo principal
Lenovo Yoga 2 11" 20428 Motherboard Replacement
O que você precisa
  1. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 4, imagem 1 %32
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 5, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 5, imagem 2 %32
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 6, imagem 2 %32
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Hard Drive: passo 7, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
  8. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 8, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 8, imagem 2 %32
    • Lift the hard drive up, turn it over, and remove the connection.
  9. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Speaker: passo 9, imagem 1 %32
    • Use the Phillips #000 screwdriver to unscrew the four 1.7 mm screws.
  10. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 10, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully detach the speaker wire and remove the speaker.
  11. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Bluetooth Module: passo 11, imagem 1 %32
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 12, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 12, imagem 2 %32
    • Gently grab and remove the Bluetooth module.
  13. Lenovo Yoga 2 11" 20428 Motherboard Replacement, Motherboard: passo 13, imagem 1 %32
    • Using your finger nail or a thin pry tool, unlock and remove the three cables.
    • Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
    • Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
  14. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 14, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 14, imagem 2 %32
    • Gently pull the cable out of the connector.
  15. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 15, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 15, imagem 2 %32
    • Lift the wide cable in the center to reveal the port for the small cable underneath.
    • Using a fingernail or a thin pry tool, lift the white bar to release the cable.
    • Remove the cable from the connector.
  16. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 16, imagem 1 %32
    • Lift the tape up to separate it from the motherboard.
    • Using a fingernail or a thin pry tool, lift the connector upwards to separate from the motherboard.
  17. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 17, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 17, imagem 2 %32
    • Remove the black tape covering the connector.
    • Pull straight backwards to remove the connector from the motherboard.
  18. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 18, imagem 1 %32
    • Pull the cable straight backwards to remove it.
  19. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 19, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 19, imagem 2 %32
  20. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 20, imagem 1 %32 Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 20, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove the seven 3.6mm screws.
  21. Lenovo Yoga 2 11" 20428 Motherboard Replacement: passo 21, imagem 1 %32
    • Lift and pull backwards to remove the motherboard.
Conclusão
Bavly Shehata
Membro desde: 03/30/22
181 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Harley Spring 2022 Membro de IUPUI, Team 1-3, Harley Spring 2022
IUPUI-HARLEY-S22S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 454
