Introdução
This guide will properly show how to remove and replace the hard drive component for a Lenovo Yoga 2 11” 20428. When removing the hard drive be sure to have the laptop turned off and the battery disconnected.
Ferramentas
Peças
Nenhum componente especificado.
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Remove six 3.3 mm Phillips #000 screws around the perimeter of the battery.
Remove one 6.75 mm Phillips #000 screw from the center of the battery.
Remove four 3.3 mm Phillips #00 screws securing the hard drive to the panel.
3 outras pessoas concluíram este guia.
