Ir para o conteúdo principal
Lenovo Yoga 2 11" 20428 Display Replacement
O que você precisa
  1. Lenovo Yoga 2 11" 20428 Display Replacement, Display: passo 1, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement, Display: passo 1, imagem 2 %32
    • Remove the plastic square covers on the hinge cover.
  2. Lenovo Yoga 2 11" 20428 Display Replacement: passo 2, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 2, imagem 2 %32
    • Remove the two 3.8 mm screws from the hinge cover.
  3. Lenovo Yoga 2 11" 20428 Display Replacement: passo 3, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 3, imagem 2 %32
    • Remove the hinge cover.
  4. Lenovo Yoga 2 11" 20428 Display Replacement: passo 4, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 4, imagem 2 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 4, imagem 3 %32
    • Remove the 2.8mm screws.
    • Remove the 5mm screws.
    • Remove the 2.4mm screws.
  5. Lenovo Yoga 2 11" 20428 Display Replacement: passo 5, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 5, imagem 2 %32
    • Remove the front cover of the display
  6. Lenovo Yoga 2 11" 20428 Display Replacement: passo 6, imagem 1 %32
    • Unplug the button sensor board.
    • Do not damage the teeth. Damaging the teeth of the sensor board may require you to replace the part.
  7. Lenovo Yoga 2 11" 20428 Display Replacement: passo 7, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 7, imagem 2 %32
    • Remove the 2.1 mm screws from the brightness sensor board.
  8. Lenovo Yoga 2 11" 20428 Display Replacement: passo 8, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 8, imagem 2 %32
    • Remove the 3.3 mm screw on the camera.
    • Removal of the camera will result in the connecting wire to be disconnected as well
  9. Lenovo Yoga 2 11" 20428 Display Replacement: passo 9, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 9, imagem 2 %32
    • Remove the 3.3 mm screw on the touch control board.
  10. Lenovo Yoga 2 11" 20428 Display Replacement: passo 10, imagem 1 %32 Lenovo Yoga 2 11" 20428 Display Replacement: passo 10, imagem 2 %32
    • Remove the touch control board
    • Do not damage the teeth. Damaging the teeth may call for replacement of the part.
    • Removal of the touch control board will result in the connecting wires to be removed as well
Conclusão
Uma outra pessoa concluiu este guia.
Devin McCuen
Membro desde: 03/30/22
181 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-3, Harley Spring 2022 Membro de IUPUI, Team 1-3, Harley Spring 2022
IUPUI-HARLEY-S22S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 192
