Ir para o conteúdo principal
Lenovo Yoga 2 11" 20428 Battery Replacement
O que você precisa
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: passo 1, imagem 2 %32 Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: passo 1, imagem 3 %32
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: passo 2, imagem 1 %32
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: passo 3, imagem 1 %32 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: passo 3, imagem 2 %32 Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: passo 3, imagem 3 %32
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: passo 4, imagem 1 %32
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: passo 5, imagem 1 %32 Lenovo Yoga 2 11" 20428 Battery Replacement: passo 5, imagem 2 %32
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: passo 6, imagem 1 %32 Lenovo Yoga 2 11" 20428 Battery Replacement: passo 6, imagem 2 %32
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 739
