Introdução
This guide will show how to properly remove and replace the battery component. The safe disconnection of the battery is a key so that you do not shock yourself or any of the other components within the laptop.
Ferramentas
Peças
Nenhum componente especificado.
Flip the computer over so the bottom is facing up.
Remove the ten 6mm screws with a T5 Torx security screwdriver.
Remove six 3.3 mm Phillips #000 screws around the perimeter of the battery.
Remove one 6.75 mm Phillips #000 screw from the center of the battery.
Quase terminado!
Conclusão
