Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
  1. There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. There are two screws that will need to be removed to access the keyboard.
    • There are two screws that will need to be removed to access the keyboard.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap  to push it back. Look closely at the two images  you'll notice a slight gap at the bottom if you did this step correctly
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  5. Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  6. Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
Conclusão
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
Corey Meyer
Membro desde: 01-05-2017
1.877 Reputação
2 Guias de autoria
equipe
Kid fixers Membro de Kid fixers
Community
108 Membros
68 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 64
